it seems as if everything pertains to A and AA batteries |
You're not seeing the forest for the trees. What the articles talk about are
cells. AAs and AAAs are single cells, not "batteries". A battery is a collection of cells, as in a 9V battery, which is 6-8 cells. (7.2, 8.4 and 9.6V nominal, for rechargeables). Treat each 9V as a collection of small cells to be charged only at 0.1C or lower, and I believe you will find those documents relevant.
is there a quick way to figure out the required current and voltage to charge a certain number of batteries. |
I just gave you the voltage rule. The current rule is 0.1 times the mAh rating of the cells in question -- or below -- for trickle charging. Also called 0.1C.
So for a 170mAh Plainview 8-cell "9V" NiMH battery with an LM317 current source and one input diode for protection, you need at least 14V; the LM317 should be configured for 17mA or less. Do you see this?
The LM317 datasheet tells you how to calculate the series resistor to get a desired current level. It's just Ohm's law, not rocket surgery.
what exactly is the C in Cma? |
I don't know what C is supposed to stand for, but 1C means the amount of mA it would take to charge an ideal cell/battery in 1 hour. An ideal 100mAh cell would take 100mA for one hour to charge fully. In practice, inefficiencies mean it won't be fully charged in one hour, but you still say 0.1C to mean 10mA in this example.
As I recall, the Panasonic book uses a different notation scheme, but you should readily suss out how to convert between the two. The old C scheme has some conceptual flaws, but everyone knows how it works, so no competing scheme has really superceded it.
