Sheerglory
- Oct 14, 2014
Hi there everyone, I'm a bit of a lurker, but I have been around for a while. I just haven't felt the need to create an account as of yet.
I have found a strange thing when equalizing my headphones with Equalizer APO across the whole system. I realize that it isn't a system problem, but more of a potential strange occurrence with physics. I was wondering if anyone else has found the same thing when equalizing their headphones. The frequencies between 8200 and 8600hz seem to only be consistent if the headphones are positioned in an optimal way.
My setup is AKG K702's with a Tube Magic D1 DAC and Amp running from my computer. When equalizing consecutive days with Sine Gen, I noticed that a few frequencies in this range would swap ears and come in and out, then the next day, after apparently fixing it, it would happen again, and never cease. This is a strange phenomenon which I have discovered and it seems that if the headphones are positioned exactly right then the transition is smooth. It does not happen with any other frequencies higher or lower, just those ones. I thought it must have been a problem with my rig, but my friend reported it also when flattening his M50's.
The positioning seems to be the reason for the change. Does anyone have any ideas on how to combat this? It's difficulty to always put the headphones on the exact same way every time to ensure a smooth transition over these frequencies. Has anyone else experienced this?
