75 Ohm SPDIF cable with mini connector? (for MicroDAC)
Apr 1, 2006 at 4:38 AM Thread Starter Post #1 of 6
heymaceo
Hi-
I have a Headroom MicroDAC whihc is being fed by a SqueezeBox 3. I'd like to use the Coax connector on the MicroDAC rather than the optical toslink. I'd like to do this with a 75 ohm cable with 75 ohm connectors. This isn't a problem on the RCA end (which is what the SqueezeBox has) but I can't seem to find the right cable with the right mini connector on the MicroDAC. All I've found is this cable:
http://www.ramelectronics.net/html/R...html#89259spec
and I don't know if it meets my needs - because they do not mention the specs on the connectors of this cable.
I'd really like to get the Blue Jeans cable but it doesn't seem to be offered with a mini adapter.
http://www.bluejeanscable.com/store/...udio/index.htm
Does anyone know if the F-connector available here:
http://www.bluejeanscable.com/pages/...anarefconn.pdf
can be used on the MicroDAC?
Anybody found a particularly good SPDIF cable for their MicroDAC with its unusual connector interface?
THANKS!
Apr 2, 2006 at 8:21 PM Post #5 of 6
I understand that I can find a cable with a connector that will fit - I'm really hoping to actually find a cable which is tru 75 Ohm across both the cable and the connectors on both ends. I can't find a belden 75 ohm cable - or any other manufacturer for that matter - that has (or represents as having) a 75 ohm matced mono minijack connector.
