shaizada
I've been doing a lot of reading and at the end of it, I'm quite confused
Here is what I wanted to do:
1) Connect the RCA outputs from my (XM radio, Minidisc, IPOD) into a switch box.
2) This will require 6 RCA plugs (Two from each device) + 2 more for future expansion.
3) One set of RCA jacks to output to the AUXILIARY in of my headunit.
4) A remotely mounted (Maybe on the dash) ROTARY switch.
My aim is to build a great quality (AND not to expensive
) "switchbox" type of setup. I'm so confused at the type of rotary switch I want.
Do I want swtiching or Non-switching? 3 pole or 2 pole....how many throws? What kind of wires should connect everything inside the box? Should I use a particular kind of solder for the joints?
A parts list and a push in the right direction would be sooooooooo helpful.
Thanx to ANYONE who replies!
PS:- I have in mind Dayton female jacks and am clueless to the rest of the stuff
