320kbps Vs. ALAC
Jul 5, 2012 at 1:30 PM Post #106 of 112
I don't think that any human can tell the difference between AAC and lossless in a line level matched blind test. I think the people who claim they can haven't done line levelling or are gaming the test.
Jul 6, 2012 at 7:56 AM Post #107 of 112
How are you doing the line level matching?
My replaygain shows a 0.06db difference in one of my converted tracks, that's pretty tiny.
Jul 6, 2012 at 12:47 PM Post #108 of 112
I put a preamp in the line to balance the level.
Jul 12, 2012 at 5:18 PM Post #109 of 112
Between lossless and AAC *what*? I mean, you know it's a variable encoder right? Clearly not all amounts of information will produce the same result.
Jul 12, 2012 at 7:20 PM Post #110 of 112
AAC 256
Oct 15, 2015 at 3:25 AM Post #112 of 112
Even that is probably overkill for a lot of music.
  the moment an Audiophile starts to compare the clarity between digital files,
they start to stop enjoying the MUSIC and start worrying..
Exactly.  I keep lossless around for backups.  AAC, Vorbis, MP3 at higher bitrates are good enough and will save you lots of space on a portable.
EDIT:  A couple suggestions for the OP.  First off, start ripping with a program that employs AccurateRip such as dBpoweramp (Windows & Mac) or XLD if you're on a Mac.  Second, I would take a piece of music you know well, and see how low you can take the bitrate before you start to notice the effects of the compression.
