Stephonovich
- Jan 6, 2003
We had two pretty much identical AMD systems; XP 2000+ on MSI K8T Ultra Combo, and I couldn't be happier with 'em. The only lockups we had I attributed to programs or Windows, as when I ran Linux, (or the other computer, which wasn't a gaming machine, and as such, wasn't tweaked within an inch of it's life or flogged as hard) everything was fine.
However, my mobo just died a couple days ago (went to go boot, nothing. Reset BIOS, had case open, hit power, smoke poured out. For some reason, a major trace running from a fan header burned up), so we'll see how the new one fares. Luckily, MSI has an extremely good warranty (3 years), and excellent (if not gullible; I basically called 'em up, said I had a dead mobo, and they didn't ask for proof of purchase or anything, just gave me an RMA) customer service, so I oughta be up and running within a couple weeks. Upshot is that these mobos are a bit old, and MSI no longer makes them, so I'll be getting a free upgrade.
Anyway, back on subject... Intel is extremely stable, I'll give it that. I've used extremely high-end gaming machines built on Intel, and they're rock solid. That being said, I'd still rather have the performance and price of an Athlon box and deal with occasional problems. If you do your homework right before ordering parts, you can usually iron out most problems anyway. Although sometimes you can discover new ones, like me. Both MSI and AMD said the Duron worked with the above mentioned K8T mobo. Suprise, suprise, it doesn't. Won't even POST. Anyway...
(-:Stephonovich
(-:Stephonovich
