Arainach
- Jul 25, 2005
Wrong on all levels. To the best of my knowledge there is no hardware FLAC decoder in existence. FLAC is decoded in software to PCM, and any compression level decodes to the exact same PCM. That's why it's called LOSSLESS. It's just like a ZIP file (which ALSO has different levels of compression, and somehow decodes to the exact same binary files), and I'm not sure why you have such a hard time grasping that.
Originally Posted by FrederikS|TPU /img/forum/go_quote.gif From a compression algorithmic point of view the different FLAC compression levels have a significant impact on the bit per bit output. In an ideal world FLAC should sound the same no matter what compression rate (0-8), but since most of the hardware used for decoding uses a different logic depending on compression the decoded result can sound different. If you examine a decoded FLAC file compression level 8 to say a level 1 there will be no difference bit wise. In theory the only things that differs is the artifacts that the hardware decoder produces at different compression levels. I'm with Quaddy on this one it's all just a matter of finding out which compression level that gives the best result on your hardware. |
