It is not either or. You can use 192 kHz when recording bats and 44.1 kHz when recording a cellist.
You can, nobody said something contrary.
First of all, nobody uses 44.1kHz when recording, like at all. You use 48kHz because 44.1kHz can trigger a lot of issues while recording. You either use 48kHz or 88.2kHz, but never 44.1kHz.
But you use one setting for the project and you stick with this setting. You don't recording everything with different settings, that would be the biggest hassle ever.
You either use 96kHz or 192kHz for the whole project and stick to it.
It is about how perfect the filters have to be to be perfect for human ears. Those who make money selling hi-res music think those filters are not perfect enough. Sound engineers in general think they are perfect enough. Go figure...
No, they don't. I don't know where you got this statement, but they don't. Even Wikipedia says don't do that as the edge cases are, where filters perform worst. You wan't some headroom to not hit the limit of the filter.
Hi-Res Music is, most of the time, mixed and mastered different and that is where most of the money goes to. Yes i know, they advertise with better sound quality and hide the fact, that you could have the exact same sound quality in Audio CD quality, still, at least in my experience, if you pay for Hi-Res Audio, you get an version that sounds different and so its not a total rip off. Because it sounds better in general. They are mixed less loud, with more dynamic/less compression and so on. So its an improvement.
And the price difference is laughable. I mean, common, whats next? Cars use more fuel than advertised? Tomatoes are not as juicy as it says on the box?
Yes, in theory filters should be infinitely long, which sounds a really long time, but in practice short filters (that are used) can get extremely close to the perfection.
As you're neither stating a runtime, nor what "close to perfection" means, thats just a phrase and nothing more. I don't know your personal opinion on what is close to perfection, so there is nothing to argue here.
In my opinion these things are the least of the problems and challenges in music production. I would be much more concerned about the ability of the drummer to play well and the placements of mics etc. not to mention how the music is mixed and mastered. It is a manufactured problem, manufactured by hi-res sellers.
You see, that is the point. In your opinion. But you don't work for major studios so sadly, no one cares about your opinoin.
Apply for a job there and tell them how wrong they are doing things i am sure you'll have a work contract with Sony Music in no time.
Even if you want to avoid this "problem", using 88.2 kHz or 96 kHz would solve it. No need to use 192 kHz.
Well if 192kHz is the default output of your digital interface, you're using 192kHz., Why take the risk? Whats the advantage?
Resample from what to what
96kHz (with LPF, of course) to 44.1kHz
You're having a stroke? Should i call a doctor? Re-read what we were talking about, you might get why.
I am not here to give financial advice to record companies. I am here to tell what the science tells. Recording at 192 kHz may make financial sense (I am not an entrepreneur myself and I understand nothing about commercial aspects), but it doesn't make sense otherwise.
Can you please show us your Doctors degree or at least your Masters degree first? We need some proof that you actually know what you're talking about.
