if resampling utilizes the same anti image filter as the dac would then resampling can change its "sound signature" too, just like the anti image filter of the dac
Resampling uses the same types of filters with the same filter requirements and obviously there are many different individual filter designs/variations. So “yes”, the different filters do change the “sound signature” (FR, phase and/or “ringing characteristics”) but NOT audibly so in most cases. It’s only in pathological cases where there’s an audible difference and such filters can justifiably be considered “faulty”, as already mentioned!
because they were still happy with it
So you’re saying that because we’re “
still happy with it” the EQ plugin we’ve apparently subconsciously inserted and adjusted (to compensate for filter “flavour”) is invisible/can’t be seen? That doesn’t make any sense, how does a plugin become invisible and how would we adjust it (even subconsciously) if it were invisible? We’re “still happy with it”, even after numerous resampling applications, because it’s not audible and there is nothing to compensate for!
how would you test it? disable or enable it... in my case in camillaDSP and pipewire
And which DACs allow you to disable oversampling? All DACs resample/oversample (with the exception of NOS DACs). If you are disabling oversampling/resampling in say CamillaDSP, you are NOT disabling resampling/oversampling, your DAC is still oversampling (assuming you’re not using a silly NOS DAC)! What you are disabling (in say CamillaDSP) is an additional/intermediate sampling step. So in the case of say a 44.1kHz input file, either CamillaDSP is implementing a 22.05kHz filter or you DAC is, there is no way to disable it (unless you’re using a NOS DAC of course), you’re just changing where that filter is being implemented.
jitter/phasenoise for example
There is no audible jitter, even the DACs in cheap consumer devices from 25-30 years ago had “jitter/phasenoise” a hundred or more times below audibility.
kinda dumb to check something that is "completely" irrelevant tho
But it’s not completely irrelevant, it might be irrelevant to consumer playback but not to engineers. We need to know the performance of say a DAC, even though artefacts are inaudible and therefore completely irrelevant to consumers, because certain workflows can require the mix (or parts of the mix) to pass through a DAC multiple times, thereby multiplying the artefacts.
well "imagination" stops for me when i can switch back and forth and the heared difference are identical...
How does it stop? Do you have a switch bolted to your skull so you can deactivate the parts of your brain that create “imagination”?
As you obviously cannot switch off your “imagination” and you have not done controlled testing (which eliminates cognitive biases) then you cannot know and again, “
if you don’t know, then isn’t asserting you heard a difference dishonest?”!
this is BS.... if i change something and it stays for weeks exactly the same till i change something else than this isnt "perceptual bias", shouldnt bias of any kind change day over day?
Why? If everything “
stays for weeks exactly the same”, including your knowledge/experience, belief and cognitive bias (expectation and others), then why would your brain ever calculate a different result, let alone “
change day over day”? Some perceptual errors stay with us our entire lives (the stereo illusion for example) others are affected by cognitive bias and those can of course change with knowledge, experience and beliefs, sometimes over the course of years and sometimes just minutes.
i dont think that your brain saves some sort of "setting" ....
Then how are you writing your posts? If your brain does not “save the setting” of say the rules of language (grammar and spelling etc.) then how could you ever communicate with anyone? Surely you’re not claiming you have no memory? When you listen to one of your favourite recordings, do you honestly have no recollection of ever having heard it before?
no one said something about the fact that ESS writes in their own manual that "filters can change the sound signature"
Yes I did, in fact I devoted a lengthy paragraph to it and you quoted some of it!
well if there is a audible difference AND it can be measured then we should question the audiblity
Why?
G
