Ghoostknight
yes thats the site2. I presume you mean the infinitewave (http://src.infinitewave.ca/) site. That’s been going for many years. Yes, you can “clearly SEE” differences between resampling algorithms because they have deliberately emphasised the visual differences! The FAQ states:
“Are most SRCs really that bad?
No. If you look at the decibel scale to the right from the graphs, you can see that the range of these graphs is very wide: down to -180 dB. The distortions generated by most properly designed SRCs are below -100 dB and can hardly create audible artifacts. The bottom line is that most tested SRCs range from fairly good to excellent, but the graphs are very sensitive to emphasize the differences.” - Emphasis mine. Incidentally, the Windows 10 DS resampler (the only listing for Windows) is very good, artefacts are roughly -120dB to -140dB and way below audibility or even reproducibility!
instead of arguing the audibility please everyone should try this yourself, imo its kinda clearly audible, and i dont think this is placebo.. for most of the time i actually checked this site after trying a specific resampling,
tho im unsure if "stuff under -100db" is the only thing the resampling "tackles", its not like i hear a noisefloor at -100db but it loses fidelity in the "normal audible range" like even on 0db to -30db, this is whats so crap about resampling
i never investigated the reason tho... does resampling alter impulse response? (since there are impulse response graphs on the site)
and this windows 10 DS actually shows noise up to -70db... in the case of pipewire its -70 vs -170 (!!!)
https://src.infinitewave.ca/?Top=Pipewire_Q14&Bot=Windows10&Spec=0111
i also think this graph : https://src.infinitewave.ca/?Top=Pipewire_Q14&Bot=Windows10&Spec=0111 shows how stuff gets reflected back into the audible range (realistically it shows stuff around -90 to -120db
but overall... why bother with bad implemented resampling if there are much better solutions... well beside windows sucks which is one of the biggest bummers imo
i actually found a really "funny" factThere are not a lot of different reconstruction filters as far as I’m aware and reconstruction filters have been trivial to implement for 30+ years. What has changed is the number of available anti-imaging filters. This is a relatively new development and is entirely driven by marketing! Before this there were no switchable anti-image filters, DAC chips all had a single linear or minimum phase filter, with typically a 2-3kHz transition band and NO audible artefacts. Then a few years ago audiophile manufacturers applied their typical scam of taking a non-issue and falsely claiming it was an audible issue, this time to anti-image filters. In response to manufacturers demands to provide a solution to this non-issue, the DAC chip manufacturers implemented switchable filters. The vast majority of which are still inaudible but there are some with transition bands starting far lower, which can be audible.
if you look into the manual of the ess9038q2m chip... you find this sentence: Custom sound signature is supported via a fully programmable FIR filter with 7 presets.
are you as shocked as i was first reading this? the manfacture of the chip thats used in 50 to 70% of all current dacs says reconsutrction filter "can" matter, how is this possible?
i mean they could have said " our chip is so awesome we support 7 ("inaudible") reconsutruction filters " but they went with the sentence above... well "marketing" i guess..
my dac actually can switch between those 7 filters and there are indeed audible differences, so much (tho its subtle if you dont know what to listen for) that i actually believe a huge part of differences heared between dacs actually come from this, also here... impulse response has a effect on the whole audible range!!
this makes it also nearly impossible to really compare one dac to another if they dont use the same filter, there could be differences in the analog section that are just overlayed by the a audible differences between these filter
ah i somewhat agree ... but minimum phase slow rolloff sounds "the best" imo and with resampling to 192khz you avoid the fact that the roll off isnt that great, imo "currently" i would say this is the best solution... IF you use high quality resampling, tho i might change my opinion on this at some point with a different dacObjectively and if high fidelity is what you’re after, the answer is: Do nothing! Typically the default filter is the same sort of filter used in DACs a decade or more ago with completely inaudible artefacts. If you’re not sure, don’t choose the option usually called something like “slow”.
