71 dB
SACD has practically two advantages (compared to CD):The only bad one for me was the Alice In Chains Greatest Hits SACD.
1) Multichannel support
2) Recording and production for SACD releases are often carefully done meaning even the stereo downmixed SACD/CD versions on the disc sound great.
That's about it. If you are re-realising old stereophonic recordings on stereo only SACD you don't have these benefits. Of course you can make a new awesome sounding stereo remaster of the old stuff and have a good sounding disc, but you don't need SACD for that. CD is fine. Only if you create a new multichannel mix of old material does it make sense to release it on SACD. I don't know how Alice in Chains Greatest Hits is. Not my type of music. As a general rule, classical music on SACD is awesome thanks to new multichannel recordings done in places of natural acoustics.
Well, nobody in their right mind would reduce the dynamic range of a classical music recording into DR8. Meanwhile, modern pop music uses small dynamic range skilfully (dynamic compression is crucial part of sound design) and DR6 can sound pretty dynamic. The same DR6 applied to a symphony would give comical results.There is no way that DR8 will sound good, specially with Rock or Classical. Maybe DR10 will sound better than DR13 if mastered well.
As I mentioned above, modern pop music uses dynamic compression in the sound design and mixing cleverly so that it works at lower DR values. Commercial music tends to be more compressed while less commercial, more "artsy" genres of music tend to offer bigger DR values. Classical music is not the only option, but one has to dig deeper beyond the commercial surface.DR8-12 are what will depend on the genre, but less than DR8 is objectively horrible no matter what genre it is, and sadly modern recrodings have dynamic ranges of 4-5 and some I saw even 2! It's impossible to be a non-classical audiophile these days.
