abbztract
- Feb 11, 2012
I went over to Addicted To Audio (Melbourne) the other day and trialed quite a few different headphones..
M50, AD700, SRH840, HFI580, DJ1, PRO700MK2, one of the Beyer DTs...and some i cant remember
Of all of them, I really liked the HFI-580 and the Shure SRH840..580s a tad more i'd say...
The guy who runs the place said that out of the ones that were available for trial, the only ones that met my needs of a CLOSED set of PORTABLE headphones that do well with HIP-HOP, RAP and a tad of DUBSTEP as well as gaming were the HFI-580 and the Shure SRH840s....
APPARENTLY, they have a soundstage good enough for gaming.. because i couldnt test them with any games, i dont really know...
I PMed a member of these forums who had recommended to another meber the SRH940 for gaming and according to him, "As far as competitive tracking goes - ie directional positioning - the SRH 940 is definitely better - it just has more detail retrieval, so it's clearer. The SRH 840 is more 'fun' though - it's more immersive because of the mid-bass. Neither is particularly good on sound-stage"
He reckons that, "If you want a cheap closed allrounder - that is really good with music, and still ok at gaming - consider the Fischer FA003 / Brainwavz HM5. You'll find plenty of reviews around for both. I currently own the HM5 - and it's a really good can"..
"SRH940 was pretty good for gaming - but very narrow genre range for music. To me, the SRH 840 was a lot better for music (not as detailed, and bass a little boomy at times - but at least it sounded real)."
Sorry about the quoting crap and massive posting, but can someone tell me whether any of the mentioned headphones are worth getting? I have read MLE's Gaming thread but didnt find much because that is based around use with Dolby Headphone..
Thanks, Abz
And i did try my luck in the "Buying headphones? Seek advice..." thread but didnt get much there so i made this thread..Sorry
Thanks, Abz
