EventVista
- May 28, 2012
Gracias! Thanks for pointing towards the L7, at minimum you saved me about $90. I think this will suite my needs perfectly. Just placed my order on Amazon....
1. Yup, the additional power certainly helps.
2. The output from the E9 (and the L7) line out is analogue, not digital. Therefore, you connect to an analogue input (AUX, for example) on your amp using an RCA cable (or a mini-jack -> RCA in the case of the L7).
Incidentally, the "other two" digital inputs on your amp will be co-ax digital connections.
HTH dude!
