CodeToad
- Jun 30, 2008
I need to finish a project I started to start some time ago. I have all my different electronics hooked up to power strips so I can turn them on and off from my chair. I made the mistake one day of turning off the one with the computer running and Windows punished my indiscretion by making me reinstall (from a current Ghost image).
I plan to use regular AC wall switches instead of the power strip mess, I have one here with 4 separate switches in one switch/plate. That will be fine for the amps/printer/etc but I don't want one single switch for the computer.
What I want to happen is to use 2 regular AC wall switches, like the standard light switches, to control the power to the computer. Both switches have to be in the same position for an action to happen, ie. both have to be down for the circuit to be off, both have to be up to be on. That way one switch can get hit accidentally or whatever and not become that days catastrophe. The switches will be located some distance apart.
I have no idea how to do this. Any ideas?
