2.7 ohm speakers on a Pioneer receiver?
Dec 10, 2016 at 5:52 PM Post #16 of 16
My apologies...  I don't know where I got the $250 from:o ...  In any event, I cannot find any information on Proson speakers using Google here in the US.  However, looking at the Dynavoice speakers...  The Dynavoice appear to be fairly good speakers by looking at the reviews, specs and pricing of a couple of their speakers by using a money converter from SEK to USD.
As long as you stick to your budget and keep the speakers to 6-ohm and within the same model-series so that they are "voice-matched", I think that you will be okay.  8-ohm speakers will work as well for your AVR, but 6-ohm is optimal as your AVR will require less power/watts to drive them.
Hope this helps...
[COLOR=222222]Sláinte[/COLOR]
Yeah I'll try to stick to 6 ohms thank you.
I decided that I'll buy bookshelf speakers and perhaps a sub and then later on add speakers. Sounds like a plan? That way I'll spend a nice amount of money on each and get good quality ones as well
