mihaig
- Feb 15, 2017
Can anyone recommend a high quality 2.5mm male to 4.4mm female adapter? And a high quality 4.4mm male plug.
Right now I have a Fiio one, which works very well with an original Sony cable but doesn't work well with a 4.4mm plug I bought from eBay (I have to pull it out about half a mm to hear sound on both channels).
Of course I can blame the plug (and I do - can see a small difference when put near an original Sony) but the seller sold a lot of them and they work if inserted directly into a 4.4mm player.
Which makes me think the tolerances on both Fiio adapter and the plug are small enough so they don't matter when paired with a high quality component, but large enough to make a difference when combined.
