Nick Dangerous
Mr. Tuberrific
- Nov 19, 2001
Tell me what you think of the new ones. I currently use the JJ EL84's, and in the past I've used the Sovteks but they sounded a bit sterile.
Originally Posted by Nick Dangerous Tell me what you think of the new ones. I currently use the JJ EL84's, and in the past I've used the Sovteks but they sounded a bit sterile. |
Originally Posted by pageman99 I won't go into details. I'll save that for a long post on each tube later. But I will say in my exhaustively researched opinion, most of Joe's Tube Lore is simply wrong for most folks. |
Originally Posted by Nick Dangerous Whatever the case, they sucked. |
Originally Posted by Nick Dangerous Second round impressions: Raytheon 5751 blackplate w/windmill getter JJ ECC803S Sovtek 12AX7LPS Ei Elite 12AX7E JJ ECC83 Electro-Harmonix 12AX7EH Let's start from the bottom up: #6 - Electro-Harmonix 12AX7EH I gotta agree with the guitar amp freaks on this one. It's a blah tube. Overall sound is slightly veiled. Bass is vague and unsatisfying. It also falls behind the other five tubes in this comparison in terms of detail and clarity. Definitely not recommended in the MG Head OTL. #5 - JJ ECC83 This tube has fallen to the fifth spot. Although it sounds wonderfully liquid in the midrange, the highs are too soft. Bass could be a bit stronger. Ultimately, this tube gives up too much at the extremes. No longer recommended. #4 - Ei Elite 12AX7E Here's where things start to improve. The Ei improves upon the JJ by delivering enough bass to get your toes tapping. Unfortunately, the rest of the frequency sounds a bit too mellow. It gives up detail for warmth, which prevents any one strength from standing out. Result: A respectable but mostly uninvolving tube. #3 - Sovtek 12AX7LPS Get one for your collection! Sovtek's latest tube rocks! Bass is deep and satisfying but never gets murky. The 12AX7LPS has the best bass of all current production tubes in this roundup. It doesn't get too "dark" either, because the high frequencies are crystal clear and sparkle with detail. The only real weakness of this tube is the characteristic "Sovtek sterility" in the midrange, but it isn't as pronounced as usual. Overall, this is a superbly balanced and exciting tube that excels with electronic music. #2 - JJ ECC803S JJ's latest creation is a hit! It replaces the mushy upper frequencies of the JJ ECC83 with shimmering highs. Now you can have your lush midrange cake and eat it too. This tube shines with classical and vocal music, or anything that emphasizes the midrange/upper frequencies. It doesn't totally spank the Sovtek because the bass is definitely weaker, but it works well enough. I love the midrange of the JJ family of tubes, so it's worth the tradeoff to me... I think. More testing is needed to be sure. I'm slotting it at the #2 spot for the moment. #1 tube is still the Raytheon, because it does everything best. However, at this rate, NOS may eventually be overtaken by current production tubes. Ah, we can only hope. My advice? Use the Sovtek 12AX7LPS for electronic and cerebral music, and the JJ ECC803S for everything else. Or, find a Raytheon and be done with it. ![]() Blasyrkh, based upon your preferences, I suggest you try one of the new JJ ECC803S tubes. It addresses the problems of the older ECC83 being too dark and "heavy" due to its rolled-off highs. |
