whirlwind
I think I see what you're doing there in the GOTL with those tubes. Great tubes to have in the toolbelt for sure. I know @UntilThen liked them a lot as well before he went all sane on us and stopped tube rolling. I also have the more slender ST type and the more bulbous ST type.
I'd really like to hear the Tele EL11's in a circuit designed for them (which is certainly not my current amp). @whirlwind or @Zachik have you tried them in the GLE3N? @A2029 I presume they will work well as powers in the EL34/KT66 amp (with EL11 to EL34 adapters).
I know different manufacturers and years have different sonics, but at a very high-level In my amp I'm finding the following (from light/airy to oomph/bass). Oomph is a technical term btw.
76/6C5, 6J5, 6SL7, 6N7, EL11/EL3N. 6J5 being the most neutral. And as @mordy rightfully says "my amp, my gear, YMMV". I'm not even sure I should include the EL11/EL3N here as my amp certainly wasn't designed for them, and I'm fairly sure they would sound different in an amp designed for them.
Disclaimer: The 6SL7 and 6N7 have higher gain (certainly in my amp). My findings are far from scientific. I haven't done any measurements - apart from with my ears with multiple different sets of recordings. Possibly under the slight influence of a single malt or a vape with a live resin.
I have not tried the EL11 in my SET amp, I would need EL3N to EL11 adapters.
I don't think I will be trying them as I am in the midst of upgrading my headphones and headphone cables and for once tubes or amps have not gotten in the way.
