UntilThen
- Jun 16, 2015
This is what happens when layman specify what they want in a tube amp. They drive the designer crazy.
"Can't I have everything?"This is what happens when layman specify what they want in a tube amp. They drive the designer crazy.
The next guy seeing this will likely ask, can I have an amp like Zachik, but also have it switchable between KT88/EL34 and the 300B?
Yeah after having experienced a quiet tube amp, there is no going back for me either.I usually only have one important criteria. I want the amp to be very quiet. No noise or hum at all or I won't want it.
It usually comes back very quiet. Zero noise.
Thanks. I got to name itBTW, cool name. Solar Flare, would burn you up (and your pockets) ROFLMAO
I strongly believe that Mischa will never ever EVER agree to build another one just like this... when you read more details in the next few days - you will realize that what I disclosed so far is the tip of the iceberg of insanity!The next guy seeing this will likely ask, can I have an amp like Zachik, but also have it switchable between KT88/EL34 and the 300B?
So far, from everything I tested - this amp is QUIET.I usually only have one important criteria. I want the amp to be very quiet. No noise or hum at all or I won't want it.
I can testify that so far - the amp is QUIET.
… best of all, it can FLOAT !!!
Thanks!One of the most original amplifiers I ever saw. Incredible.
I will let Mischa answer this one... Just to make sure I am not providing a wrong answer here.But it has manual fixed bias right? Otherwise you would be able to use 12A*7 and 6922 in the same sockets but with an adapter. Both are noval but bias differently. Right?
