Xcalibur255
- Feb 4, 2008
I'm in a typing mood so I'll take a swing at this.
I guess it depends upon your school of thought. On the objectivist side, any distortion is bad because it represents a modification or deviation of the original input signal. If what goes out isn't matching what went in then naturally we're not hearing the music exactly the way the microphones heard it.
On the subjectivist side, a number of very prominent and respected amplifier designers who have been doing this for decades have come to the conclusion that some amount of 2nd order harmonic distortion is helpful rather than harmful. The folks at Innerfidelity did an interesting listening trial using a device designed to inject varying amounts of distortion into the musical signal, and they found that people broadly preferred some degree of 2nd order harmonics to be present as opposed to the signal being as "clean" as possible. It's a matter of degrees though. A bit of 2nd order often gets perceived as an "organic" sound that enhances musicality, where as too much makes the music sound overly bloomy or smeared. Think of it a bit like looking through a pair of binoculars that aren't quite in focus. The more 2nd order distortion the less in focus things get, but just a *tiny* bit out of focus can take the hard edge off of things in a pleasing way and can call attention to overtones and harmonics in the music that gives the impression of things sounding more dense or ethereal. I would say a fair amount of what people are tuning in the sound of their tube amps when they roll tubes is the amount of 2nd and 3rd order distortion present.
As for how to interpret the graphs, what it is showing is a test tone at 1Khz. What the numbers represent are sort of ghosts or echoes of the original tone at a much lower intensity or loudness than the original signal itself was. The higher the harmonic, the more "distorted" it is from the original tone and the more different it is. Think of it like shifting the hue of a color. If our original color was pure red, then 2nd and 3rd order distortion would be just a tiny shade off..... maybe coming off as just a tiny bit more pinkish. Now as we get further into 4,5,6 order and so on the shift starts to become more visible and readily identifiable, and maybe by the time we hit 9th order now it doesn't look red at all anymore. Now we can clearly see that it has become mangenta or even purple and is a totally different thing from the original. We perceive harmonic distortion in much the same way. The brain hears 2nd and 3rd order distortion as fundamentally the same as the original tone and kind of just averages it all together as part of your subconscious processes that filter your senses. This is commonly called "masking." The further along you go, the more your brain begins to identify the distortion as its own unique thing that is different from the original sound. Especially stuff past 6th order, these residual harmonics are in contrast to the orignal tone instead of being complementary to it. A very small amount of 8th or 9th order distortion can hurt sound quality a lot, making things sound harsh, or hashy in a way that can be hard to put your finger on. On the other hand you can have quite a lot of 2nd order distortion and not really have anything bad happen to the sound other than a slight softening or smearing effect.
This is, generally speaking, why push-pull tube amps and single-ended tube amps sound different. The push-pull circuit naturally cancels out the 2nd order distortion, but any higher order distortion beyond 2nd will still be present. So you've lost the masking effect and any nasty high order distortion that might be present is that much easier to perceive. That's really a generalization though, and there are plenty of push-pull designs that sound great. In raindownthunda's post comparing the difference between CCS and resistor bias mode in his amp, he's really describing the difference between having more or less 2nd and 3rd order harmonic distortion because that's what the CCS primarily does is make the tube operate as linear as possible which lowers those distortion levels. There's still some present even with the CCS of course, because tubes gonna tube, but a big part of why tube amps seem to run the gamut between being very clear and very lush sounding is the varying degrees of 2nd and 3rd order harmonic distortion their circuit is producing.
