ofb
- Sep 22, 2002
i'm muddling my way through parts for a meta42. doing fairly well for the lost, thanks to headwize/head-fi/tangentsoft/et al, but i've run into a stumbling block with parts selection where the needed caps are obsolete, like C1 through C8 for the SDS psu.
i'm fairly sure P4125-ND is the part to substitute for P4033-ND, C1-C4. specified is a 560pf ceramic 200v. nearest digikey seems to have is the 1000v P4125-ND. sound reasonable?
but for the rest i get jammed by many seeming similar items in the digikey selection. for example C7,8 is the obsolete 330uf 25v panasonic P5703-ND.
for "330uf 25v panasonic" digikey serves up 16 items. obviously i don't want SMD, but after that it gets muddy. P10272-ND and P10273-ND have identical descriptions. P1182-ND and P5542-ND might works too; i can't tell what's really the difference here and if all or none are suitable for this psu.
perhaps someone who's gone through this part of the learning curve recently could give me some pointers? what's the method here? what's the key terminology? [and is it simply to post "hey erix, what part #'s did you use?"
