comabereni
- Aug 1, 2004
I'd like to give my 8" passive, sealed enclosure subwoofers their own amplifier. I'm considering the 120-watt model from Parts Express.
My question:
What happens if I wire my subs in parallel to this one amplifier (i.e. splice into the wires shown on the back side)? Does this mean the amp will be operating at a 4-Ohms rather than 8-Ohms? It seems I use to see powered sub/slave sub combos--I assumed plugging the second sub in simply dropped the impedence to 4 Ohms. I believe the nominal impedence of each of my passive subs is 6 Ohms--not sure if that matters.
Amp specifications:
[size=x-small]Power: 110 watts RMS into 8 ohms @ 0.1% THD
156 watts RMS into 4 ohms @ 0.2% THD
Bass boost: 6 dB @ 30 Hz
Signal to noise ratio: 98 dB (A-weighted) [/size]
I considered using (2) 70-watt or 100-watt amps and running RCA line-in to the first, then daisy-chaining from RCA-out to RCA-in on the second amp, but I'd like to do it with one amp if I can. Not sure I like the 6 dB bass boost at 30 Hz--some of the other amps at Parts Express either do not have this or it can be varied.
My question:
Amp specifications:
