Well, maybe it's the gear ratio, but in terms of spatiality, depth of sound, and stereo width, the FX17s are superior to the Solitaire T.This is even more intriguing and incredibly useful information for me (and Solitaire T owners)!
My ears are small-to-medium sized, close to the inner ear cavity of the Solitaire T, so I am lucky to not have either the slightly-on ear feel or sensitivity issues some do with those headphones.
For whatever reason, I also don't have issues with sweat wearing them either, though I do wear spectacles and try to get a good seal. On that point, it takes about 15 minutes for that synthetic leatherette to properly seal, as they need to warm up.
The Solitaire T has very notable treble that, to me and others, is just, just, off sibilance, and just off peaking into harshness that becomes fatiguing. That is to say, it is on the edge, but does not peer over, into either issue for me and a number of Solitaire T owners (looking back at both reviews and the Solitaire T thread on this forum).
Unfortunately, the overall space of the Solitaire T is quite narrow, though tall, an area I lament upon (this is sometimes why I listen to the N5005).
Bass is dependent on the quality and dynamic range of the piece of music I'm listening to; if it's well recorded/produced, it's utterly absorbing and realistic, with deep slam, texture and speed, but at the cost of bass volume. On very dynamically compressed music, Solitaire T's bass, especially sub-bass, is left wanting.
That said, to replicate the almost organic, addictive naturalness of the Solitaire T is what I am craving in an IEM that is not part of summit-fi (a segment I cannot currently afford, though I do wish to covet certain avant-garde earphones!). So far, FX17 seems to fit my sonic needs and is competitive to higher priced offerings, whilst being unique unto itself!
I should add, the Campfire Trifecta IEM's, whilst absolutely not the most perfect frequency response, has the best sound pressure effect of speakers, which with the three dynamic driver topology and implementation has the effect of naturalness. Though I would wish to own Noble Audio Chronicle, PMG Audio APX SE, Canpur CP622B, or even Unique Melody Amber Pearl for sonic virtues, to feel the sound pressure (beyond bone conduction driver tech) is something I rather like my Solitaire T can do, and something I think the Trifecta aces.
In your opinion, do you think the FX17 has that kind of sound pressure feeling or effect?
Further, I am concerned about an aspect you spoke off; if I understood correctly, in your experience the spaciousness of FX17 is less than the Solitaire T?
Could you elaborate more on this, and add any further observations you have made (especially naturalness and texture)?
Thank you, and please continue to enjoy or talk about your experiences of the FiiO FX17!
Otherwise, I have very little experience with IEMs. Before the FA19, I had the first version of the Beyerdynamic Xelento with a cable a long time ago. All I remember is that they sounded very clear and bright, but with less bass. Plus, they keep slipping out of my ears.
@Tobit
Ah, okay, thanks. I was just browsing FiiO's website and came to the same conclusion. I've now installed the medium size and am testing it.
