【Effect Audio】 - New Product Launch - "Janus"
Mar 16, 2018 at 2:51 PM Post #31 of 41
That makes it a bit more reasonable...why did they plate copper with palladium? I'm not trying to be sassy, but what are the sonic advantages?
Mar 16, 2018 at 3:08 PM Post #32 of 41
The sonic advantages are the same as silver-coated copper - nothing.
At audio frequencies (~20kHz), the skin-depth of copper/silver is on the order of 0.5mm - i.e. thicker than the cable diameter.
Hence, the audio signal travel down the bulk of the conductor(s)...
Marketing.
It's nicely done. But, it's still just a gimmick.
Mar 16, 2018 at 3:10 PM Post #33 of 41
Palladium isn't as conductive as say, copper or silver. Simply put in almost all cases, less conductive = more resistance. A different resistance could mean a boost and attenuation at various frequencies, colouration of the sound, etc. What would a metal such as palladium do to the sound over say silver or copper (or gold), suppose we'll find out when it's tested! Is a higher resistance an advantage? that truly depends on your ears. Though the plating will be extremely thin compared to the copper used... so i don't think it'll effect it at all.
Mar 16, 2018 at 3:14 PM Post #34 of 41
@BoomBox hmm, the resistance thing makes sense, I mean I'm sure its really well made and sounds good, Effect makes awesome stuff, it just seems like such a transparent instance of marketing hype.
Mar 16, 2018 at 5:25 PM Post #35 of 41
These cables were being showed at Canjam NYC without a name, I'm sure someone here has listened to them.
Mar 17, 2018 at 11:29 AM Post #36 of 41
Maybe they couldn’t even tell a difference and just assumed it was from the regular lineup
Mar 17, 2018 at 11:57 AM Post #37 of 41
That was not the case here, the cables were not showed on the table, only was asked if someone wanted to try out. As for the differences, I was the one who tried most of their lineup. These new cables had very interesting sound signature, decent quality not lacking anything though I still prefer Leonidas to anything else on that table for its naturalness of tone.
Mar 20, 2018 at 3:43 AM Post #38 of 41
I can agree with you, the Leonidas is a wonderful cable, period.
Will listen to the new cables at the CanJam Singapore !!
Mar 20, 2018 at 10:52 AM Post #41 of 41
I think we should just sell our audiophile cables and just purchase real gold for future investment.
