Kodhifi
- Jan 6, 2013
The clips that notch into the headphone adjustment divots on the headband are very loose, and I could also make do with a new headband I think. I wear these things on average 10 yours a day and I've had them almost 3 years now, been through 3 sets of ear pads hehe. They could use a spruce up to be 'good as new'.
If you take apart the 2 screws at either end of the headband you open up the adjuster and inside that, and attatched to the aluminum ear piece is a little piece of plastic that is responsible for clicking against the adjustment holes on the aluminum part. I need to find 2 of those so that my adjustments stay, right now it takes almost no force to make them move, and there is a lot of play.
I am also looking for a new headband. My 880's came with the plastic and foam band, and I'm looking for something leather if possible, or a new headband if not.
Any ideas? Google was unfruitful.
