Omega17TheTrue
- Sep 3, 2008
Hello, i have electromagnetic noise from my graphic card going to my active speakers (KRK VXT6), the more the GC work the more there is strident noises going in my speakers (and different tonality).
Here a diagram :
The cable is unbalance RCA (pre-amp)>XLR(speaker) : S is the Signal, G is Ground
When i unplug the Left or Righ cable there is no more noise, strange.
Inside of pre-amp :
Red is the ground, i cut the cable at A but it really worsened the problem, should i remake the connection ?. B is a ground point of the chassis that go to next picture.
Outlet ground of pre-amp : There is resistors on the ground output, can i solder a C cable ?
What should i do ? Can i solder resistor at pre-amp input signal ground to fix the problems ?
Note : there is a button behind the speaker that lift the ground and make the noises louder.
Here a diagram :
Inside of pre-amp :
