beerguy0
- Apr 5, 2004
Please don't sand plated tips. This only serves to damage the plating, insuring that the tip will be completely useless. If you keep getting crud buildup, the best way to clean it without damaging the tip is a soft-bristled brass brush. Metcal and other manufacturers recommend this method for cleaning tips. You can also buy tip-cleaners, which work very well. The type I use is basically fine solder beads embedded in flux.
Wipe and tin the tip frequently during use. Always make sure the sponge is wet. A dry sponge will also damage the plating.
