Topspin70
- Sep 12, 2012
Glad to hear that, having just pulled the trigger on the Jot.
So your opinion that hd650 have similar soundstage to T1??? This a very good joke if thats what you mean
Has anyone heard an HD800S through a V281? I'm really close to pulling the trigger on a set to pair with my LCD-4 and am just wondering if this is a good match. Thanks!
I have the V280 which I understand to be basically the same amp section as the V281 but without the preamp. As long as you avoid warm sounding DAC's with the V281/HD800S pairing, you should be okay.Has anyone heard an HD800S through a V281? I'm really close to pulling the trigger on a set to pair with my LCD-4 and am just wondering if this is a good match. Thanks!
The V281 has a warm signature if I remember correctly. Having had mostly warm amps so far I think a neutral and clean signature may bring out the real character of the HD800S.
I'm not sure what you mean by the "real character" of the HD800S. I consider both my Elise and Euforia OTL amps as pretty neutral, but their character and level of performance can be varied quite a bit with tube rolling. And it's not just the amp that is important, but also the DAC. I consider the HD800 as a highly resolving, relatively neutral headphone that scales quite well with the quality of the upstream chain. I don't think it requires any real trick to sound good, other than quality source and amp. But it is resolving enough that I think it is difficult to chose DAC and amp without significant home evaluation.
I didn't really like it. I also heard the Focal Utopia from the V281 and I also didn't like it.
I was simply missing high fidelity like from my home rig. But best is to listen yourself and see what you think of it because I am used to the sound of TOTL equipment.
The Hugo 2 is probably worth checking out also if you are going to try out the V281.
I have to agree pertaining to the Violectric house sound not being warm but maybe more like slightly lush, but not to the degree of many tube amps. One thing I've noticed in my experience with the V280 is it sounds leaner and faster as you lower the gain from 0 down to -12 while it sounds lusher as the gain is increase to +12.I don't necessarily consider the V281 to be a warm amp. Its very revealing of what is downstream of it just as any of the higher end amps can be. I find it to be a perfect match with the LCD-4s. I recently made a change in Dac's from the Chord 2qute to the Ayre Codex which to me was a huge step up in detail retrieval. My chain is as follows.
MacBook Pro > Cardas Clear USB > IFI Iusb 3.0 > Cardas Clear USB > Ayre Codex > Cardas Clear Balanced Interconnects > Violectric V281 > LCD-4s with Silver Dragon Cable
I think I will just reach out to The Cable Co and get a loaner set to try out. I'll post some impressions on my setup whenever I get a set.
Auditioning sounds like a good idea when your all ready at the level of the LCD4.
I usually use the Utopia with the V280 due to the availability of the lower gain settings but I did use it with the HD800S today to jog my memory of the pairing. Basically, with gain set on -12 (because I was to lazy to adjust it) there is no way IMO the HD800S can be considered to be lacking in detail or clarity. Chain used as follows.Lush is the perfect word. It seems like some people think your listening to mud when you say Violectric for some reason. And agreed on the gain. The V281 is just 2 V280's stacked together to run fully balanced. But I have to run mine on unity gain with the 4's to get enough volume around 12 o'clock.
I'll have a set of HD800S on the way in the next few days. Can't wait to get an idea of what it sounds like!
Thanks All
I feel like the HD800s is totally great out of a neutral amp and DAC. The HD800 on the other hand I prefer with some warmth in the chain. It doesn't necessarily have to be a tube amp, since there are some solid states that tonally work perfect for me with the HD800... So I agree with you that "Quality" source and amp can make all the difference with the HD800. Do you feel the same goes for the HD800s, or is it more forgiving to both due to its slightly warmer tonality? (this is all relative to the HD800 I am comparing it to.)I'm not sure what you mean by the "real character" of the HD800S. I consider both my Elise and Euforia OTL amps as pretty neutral, but their character and level of performance can be varied quite a bit with tube rolling. And it's not just the amp that is important, but also the DAC. I consider the HD800 as a highly resolving, relatively neutral headphone that scales quite well with the quality of the upstream chain. I don't think it requires any real trick to sound good, other than quality source and amp. But it is resolving enough that I think it is difficult to chose DAC and amp without significant home evaluation.
