I thought I saw the name before now you're looking at Beyer's too?
Sennheiser HD600 or HD650 ?
- Thread starter Renato Fury
- Tags
- sennheiser
Renato Fury
- May 15, 2017
It's because I'm Brazilian, and here the taxes and the dollar has sky-high prices, while in the United States the HD650 costs only $ 315.00 in my country they cost R $ 1,460.71 and that's the cheapest price, look I've already found this Same product costing more than $ 3000.00 but as those of Beyerdynamic are a little cheaper I decided to buy them even preferring those of the HD600 line, but now that the job I go to start will not happen anymore I will not be able to buy No headphones of any brand, so my dear deen thank God for not being born in a junk country like Brazil.I thought I saw the name before now you're looking at Beyer's too?
Sorry don't understand " my dear deen" totally understand this is not your native language.
Renato Fury
- May 15, 2017
Well, I'm using google translate, but I meant that you're lucky not to live in Brazil.Sorry don't understand " my dear deen" totally understand this is not your native language.
I got it now. Never been there sorry you dislike it so much.Well, I'm using google translate, but I meant that you're lucky not to live in Brazil.
Been to Rio and it is beautiful. Just glad I am not trying to buy headphones in Brasil. ---(
wsqqq777
- Aug 21, 2016
Just sold my HD650, because I feel it not 'smooth' enough. I may go for HD600 later.
ProtegeManiac
If the smoother, flatter curve of the HD650 at the upper midrange and treble isn't smooth enough for you, the HD600's 3500hz will have some midrange glare.
Skip that and go with the LCD-2, maybe go with a used pre-Fazor unit.
The Medusan
- Apr 13, 2017
I have HD650's and enjoy them very much. Ideally you would be able to trial both the 650's and 600's before making the decision, but that is hard to do. I wasn't able to either, and just took the dive on 650's based off of recommendations from people i know. I still aim to try the 600's at some point for comparison.
650's are slightly warm and a very relaxing listen, while not forfeiting any detail, and I definitely recommend them; however, I will list out the negatives I can think of to help you decide if they are right for you:
1. Sometimes find myself wishing for more sound stage as they are pretty intimate in presentation, but it isn't something I can't live with.
2. The mid-bass is a little bumped. It doesn't sound unnatural or anything, but particularly kick-drums are noticeably emphasized.
3. The sound is very reliant on the condition of the pads. Luckily Senn has a great stock of replacement parts and it is very easy to maintain your Hd6XX series headphones, but you should have the expectation that there is some upkeep. New pads will probably last around year of heavy use, and then you will need to replace them. Otherwise the driver gets too close to your ear, bass is much more elevated, you generally lose the signature sound. Replacement pads are around $50 off amazon, not terrible as an annual upkeep but a factor to keep in mind.
hope this helps
hope this helps
ProtegeManiac
The Brainwavz HM5 earpads can fit over the plastic mount of the stock earpads (you have to rip out the foam and velour off a worn out pair) and then that goes back onto the earcups. I use the angled pads and they move the cymbals closer to the center and farther back. People tend to think of that as "smaller" soundstage but really, what band has the cymbals off to the flanks? Not like it's Mr. Fantastic with his stretchy arms on the drums.
The Medusan
- Apr 13, 2017
Are the only noticeable changes with that pad swap in that region of high mids/treble? Or is the flavour of instruments other than high percussion changed as well.
ProtegeManiac
Apart from moving the cymbals closer to a more believable location given the scaled down soundstage, the sound is also less "splashy," and by that I mean, "it's less like getting hit by water like it was shrapnel after this 500lb guy dived into a pool. It won't remove all the "sparkle" (note that mine is the angled veloud; non-angled or the leather and hybrid versions could have a bigger effect).
The Medusan
- Apr 13, 2017
Interesting, I'll have to try it out. Those pads would certainly be a more durable/cheaper replacement.Apart from moving the cymbals closer to a more believable location given the scaled down soundstage, the sound is also less "splashy," and by that I mean, "it's less like getting hit by water like it was shrapnel after this 500lb guy dived into a pool. It won't remove all the "sparkle" (note that mine is the angled veloud; non-angled or the leather and hybrid versions could have a bigger effect).
thasneakershop
- May 27, 2017
Sennheiser HD600 is more bang for buck
