pinnahertz
- Mar 11, 2016
That was in your room, to your ears, with your crossover filter and with that particular song. 1. Professionals have seen many more examples and that's why they end up recommending something different as "good enough for most people". 2. 80 Hz is a bit high, for example; a better crossover for most contexts is 60 Hz if you're going to use a single sub. 3. Also the crossover slope can make a difference: 12 dB/octave is pretty bad, as it lets audible amounts of "wrong-frequency" material into both of the channels it's supposed to separate, and then the sub will give away its position by reproducing things it wasn't supposed to reproduce. 4. Also the sub should be high-quality, i.e. with very low THD, otherwise, again, it might give its position away. 5. So the choice seems to be roughly between an excellent sub + an excellent crossover on one hand, or whatever crossover you can get and whatever 2+ subs you can get, if the goal is to preserve correct soundstage down to the bottom of the spectrum.
1. As a Professional, I have not seen very many examples that didn't require or benefit from the 80Hz setting, largely because thats a frequency where most mains and are still working well. Cross over there before things start to get ugly.
2. The article you linked to deals with the specific case of mains with strong extended bass response and a bass management setting of "Large" that permits that response by not rolling them off. A single sub pretty much never really works well except for a (hopefully desired) single seat in the room. Any system requiring my services has more than one sub, I've never specified less than two.
3. 12dB/Octave is not necessarily bad if the splice (that's the frequency band where both mains and subs hand off to each other) is carefully managed. But that's true for any crossover slope. Steeper crossover slopes don't get you away from issues in the splice. This is where measurements come it, along with a means to respond to them in both frequency and time domain.
4. Past a sub producing horrific amounts of distortion (again, not a world I working in much) what gives a subs position away mostly is intensity cues. Using a single sub, often near field, has this issue.
5. No matter how excellent a sub is, and how "excellent" a crossover is, a single sub will hardly ever produce an even bass spectrum over a large listening area, or even a small one, unless the room is very, very large and sub position can be optimized. The benefits of multiple subs is not small in this regard.
edit: goofed on #1. should have been "didn't"
