Hello again Mike
Yes the PSU comes stock with AD843s. Apparently they balance low noise with dynamics.
Below is the explanation given:
"The regulator error amplifier is an op-amp and the device chosen, the AD843, gives best all round performance. The AD825, on a surface mount to dil8 adaptor, performs equally well but is marginally less convenient to use. Lower noise can be achieved by using op-amps such as the AD797 or LT1028, whilst better dynamic performance can be had with the LM6171 or AD817. All nasties, such as noise and ripple, on the output of the Super Cascode power supply are at least l00dB down."
Neither the Amp nor PSU has gone up in smoke so I assume they might be working ok. As far as heatsinks go, its abit of a tight fit as they will short if they come into contact. For the AD843s I May try getting and dremeling some of the chip heatsinks that computer overclockers use on their memory chips. When thermal pasted on they may improve heat dissipation a little.Maybe!!
I agree with you about the MK3 being a rushed design though the Super Cascode seems like a fairly sound bit of design.
Everything played through the headphone amp especially sax and female vocals really does sound far cleaner and like several veils have been removed from the performance. As the cascode has two totally separate channels, I may try feeding each channel direct into each of the P3s of the headphone amp.
I may still build the MK3 when I can track down a supplier of all the welwyn resister values required.
Is your new heed amp any better than the WNA mk1 & MK3??
Many thanks for for your help.
John.
