gibosi
- Oct 18, 2012
C3g's seem to get ridiculously expensive and rare. I wonder would it be possible to make adapters and heater voltage source (like in 6as7 power tube mod.) and get c3m or something similar working? Would it be safe for LD IV SE?
C3c's would look cool
Yes, compared to the standard recommended LD tubes, C3g are expensive. However, compared to other premium tubes used in audio, such as 6AS7, 6SN7 and 6DJ8, they are not ridiculously expensive. A pair of C3g can often be found for around 100 US dollars. Premium double triodes (equivalent to a pair of C3g) often go for hundreds of dollars. Further, these are 10,000 hour tubes, so two pairs will very likely outlast your amp.
As to running a C3m? Sure. As the old adage goes, "If there is a will there is a way."
First, you would need to be provide the tube with 20 volts to heat it. Second, the pinout is completely different than a C3g, so you would need to built a custom adapter, 8-pin loctal to 7-pin miniature, to reroute the pins. This should not be all that hard to do, but would the end result be worth the required time and treasure? I have no idea....
