stalepie
- Mar 11, 2015
Can someone point me to a scientific paper that provides studies showing this?
*causes
*causes
Neither of those are links to studies. I figure it would be unethical to do, though perhaps done on prisoners in the Soviet Union or something at one time.
Thanks. That PDF (http://applications.emro.who.int/im.../Int_J_Occup_Environ_Med_2012_3_3_136_144.pdf) seems a little lame though. Just a questionaire to 20 people about their feelings from the last 10 years. Not even a high sample group.
I don't know what you're going on about, but I am interested in individual differences in hearing loss or how some people's ears seem to be stronger or less susceptible to damage.
Tyl" wrote: "When you are exposed to loud sounds, small muscles (stapedius and tensor tympani) in your middle ear tense to increase the mechanical impedance of the system of small bones (oscicles) that move vibrations from your eardrum to your inner ear."
But with muscles some people are stronger than others. They have different potential, or using their muscles also makes them stronger. It is also interesting to me that when a bodybuilder pumps iron he is tearing his muscles, breaking it down I've heard, and then it has to repair. Perhaps there is some correlation here with the muscles in the ears.
That depends to what degree the bodybuilder damages those muscles. Too much damage and the repair will never be quite as good as before the damage. Also, with bodybuilders we're talking about relative massive muscle groups, not the tiny, delicate muscles found in the ears. In the case of hearing, too many or too much TTS's gradually (or immediately in more extreme noise cases) stops being temporary and becomes PTS (permanent threshold shift), that's permanent hearing damage and a surprising number of people have it, many of whom don't realise it and that number is increasing, even amongst children and teens. Again, many studies bare this out, as you'll see by doing a google scholarly article search. As a further hint, when you find a study/paper applicable to what you're looking for, head for the "references" section at the end, that will give you another bunch of papers/studies related to that paper.
G
being less susceptible under specific conditions probably happens, simply because humans are just different enough in most ways for some variations to exist.
... it isn't the muscles that are actually being "damaged" or "torn" in hearing loss so its a false equivalency to use the "bodybuilder" example - its the hair cells of the cochlea that are damaged
