Tom Blake
They do stack nicely without the rack though. iESL runs cool so there seems to be no problem stacking them.
This is not the right place to be seeking help with this issue. It sounds like a fault. Open a support ticket here: http://support.ifi-audio.com/
The folks at iFi are very helpful and will talk you through any diagnostics that may be done. If they cannot get it to work, they will replace it for you. No doubt they will want the faulty one back to see what is occurring (if it is faulty). So far there are next to no issues with these so you have been unlucky.
Nice!They do stack nicely without the rack though. iESL runs cool so there seems to be no problem stacking them.
They function beautifully as a tandem! The iESL only needs the included short HDMI cable for connection to the iCAN. You don't even need to use the included iPower adapter. Adding the iESL is just like an extension that allows electrostatic headphones to now be used. I do need to run the iCAN at +9 dB to get decent volume out of my Stax L500's. I currently have the iESL impedance control at 64 ohm. The volume gets louder at the 24 ohm impedance setting but I am not sure yet if that is safe for my Stax. With iESL set to the iCAN input powering down the iCAN also powers down the iESL. Basically they function as 1 combined unit.Please post how they may function together in tandem, and any potential heating performance over time with a silicone pad over the iESL venting if non-issue..
Does the iESL not function without the iCAN unit attached?
Also, impressions of the iESL balanced XLR for dynamic cans would be nice to hear impression vs the iCAN.
Correct - it is designed to work in concert with the Pro iCAN. iESL needs some form of external amp to function either Pro iCAN, an external speaker amp, or an external HP amp that is very powerful with an XLR output (at least 7V output). It works beautifully with the Pro iCAN, as one would expect.
I had the same question as @erdawe and you answered it perfectly. I had the wrong impression that the iESL was a iCAN Pro + electrostatic capability. On closer look, it doesn't have settings like gain, tube, 3D or Xbass. So clearly design to pair with the iCP.
It's not a problem at all. Light pressure on the iCAN keeps everything stable when plugging/unplugging headphones, including Stax. I do think the rack will be better though once available. In the interim stacking the 2 boxes seems to work quite well. The iESL continues to run cool having been on for 72 hours straight and I see no signs of distress. The iCAN continues to operate at its same toasty level on top of the stack.How does stacking them working out with regard to ease of inserting and removing headphones? I found that I need to hold on to the iCan to do this, I guess one needs a to apply greater pressure in order to keep the bottom iESL inplace for removing ir inserting the headphones.
I am considering buying a second iFi iCAN Pro to have more headphones connected to the same kind of device at the same time.
Would it be OK for heat flow to stack two iCAN Pro on top of each other? (I feat not)
If not, what would you recommend ?
No doubt iFi would be happy, but this seems wasteful. And besides, wouldn't you need to unplug and plug something in the chain to use the second amp? Doesn't that defeat the convenience purpose?
My wholesome recommendation is to just deal with plugging in headphones. Sorry if that sounds mean, but it is what I recommend.
Stay updated on Forza AudioWorks at their sponsor profile on Head-Fi.
