HI,
Do you know what kind of info shows up on mac audio midi set up with a usb to spdif convertor. ie sample and bit rate and can it be altered in the same way that a dac's settings can. especially for breeze du-u8 or ifi convertor etc but in general for usb to spdif convertors. ive been told for eg some convertors have a fixed sample rate output regardless of sample rate input from usb side from computer. finally how do you know 100% that the convertor is actually inputting a coax signal into the dac as the dac does not show up in settings. or is that an obvious question ie the dac would not output any signal to the amp and you would have no sound if the coax signal was not entering the dac. i am completely new to the usb convertor world. thanks mk.
