apaar123
- Sep 10, 2016
I have a lg g5. Should I buy this or lg g5 HiFi plus?
Vs. the E07 which I had before, it's definitely worth the difference. One thing to be aware of if you are wanting to use an Android device as a source is that the E17K isn't designed to work with Android (according to Fiio) and may or may not work.
The E17K didn't work with my previous Android 5 phone. I just upgraded to an Android 6 phone and have used it once with the E17K. It works and sounds good but its display only registers 48K / 16 bit which can be a sign it is working as an amp but not a DAC. It certainly sounded better than the phone, but I only had a limited time to listen so I need to check it out again. The Dragonfly Red and Black are also strong contenders in this price range, and do work with Android.
how does it compare to wm8740TI's PCM5102 DAC fed by SaviAudio's SA9027 USB receiver.
So it won't work with an android?
Do you say the E12 is more transparent and balanced because of it's FR? Because the E12 has the more colored FR: http://i90.photobucket.com/albums/k240/ofey_s/FiiO/SpectrumE12.png
The entire spectrum is literally titled up towards the treble. The E17K is perfectly flat besides some .25 dB roll-off in the bass and treble, basically negligible. If you're talking about representing the headphone purely as the manufacturer intended, you're getting relatively colored sound with the E12 (unless that kind of bright FR is what headphone manufacturers use as a testing baseline?).
Try this - adjust the volume at any frequency by 0.25 dB and see if you can tell the difference. Saying that E12 is coloured because of a 0.25 dB change (which is basically inaudible - and especially so when listening to music) is a little misleading.
