barryt
Member of the Trade: Austin Audio Works
- Apr 21, 2014
The problems is a physics issue. Your speaker is called a transducer because trans-duct energy. Electrical to Mechanical to Electrical. It is a linear electric motor. It trans-ducts electrical energy into physical displacement of a diagram and vis-a-vis the back other way.
is
The electrical energy that does not become mechanical energy becomes caloric Energy, photons if you like, in the form what we call heat. When the voice coil can not move, and energy is applied, it is nothing but a Kelvinic Heater. Unfortunately we have to used flexible glues to glue the voice coil to the speaker 'cone'.
When the coil heats up, the glue of softens, frequently the voile coil will shift enough to let the voice coil (now out of alignment) touch or scrape against the walls of the magnetic gap it is in. Then it goes to hell until the solder joints from the wire that is the actual voice coil simply melts, temperature then goes up fast until something in the conduction path melts and we have an open voice coil failure.
Electrical energy that did not become sound became heat.
So much to that root failure mode.
DC offset from a power source simply heats the voice coil because it is not doing any work. It is just cooking away.
When the speaker is working the energy from the source becomes sound and not heat. It the core can't move it becomes hate and not sound.
If you try to move the voice coil faster than inertial will let it move produces heat.
Typically audio signal energy is the sum of a group usually related energies. Any given single audio source is a collection of various 'notes' each of which as a timbre of it's own. It is typically perceived as an identifiable sound, the pluck of a guitar is an example, they are brought together in an ensemble and will call it music.
Here is guitar note, you have heard it many times. The next two suggest that 'clipping' a sine wave is produced through the addition of energies, in this case harmonically related but of warring phases relationships. Feed this to a loudspeaker and you will produce heat.
So . . . this is all a bunch of crap!
It is just talk about corner-cases in audio done in smoky back room.
You asked a practical question so you are owed a practical answer,
Try this general line of thinking . Make the first thing in your audio system be the one to run out of headroom. That is the Tape deck, PC, Cable box, Disc player, I-whatever, phono preamp, tuner, what ever you listen to, make it the first to clip.
You may have to pad the signal, you may have to amplify it, but in the end make it the first stage in the process that runs out of headroom and you be cool!
is
