Strangelove424
- Apr 4, 2012
If you roll off highs with EQ, roll off a little sub-bass as well, add white noise around the sound floor, a hint of inter-modulation distortion, you should have a fairly good idea of what exaggerated tube sound is. Not all tube amps were built to sound the same, but when people go looking for "tube sound", you can safely assume they aren't looking for tubes that measure/sound like an SS amp (which are quite expensive, and uneconomical compared to SS), they want the full on distortion experience. Getting back to the idea of using a software plug-in or filter, tube sound could be mimicked by introducing an artificial blend of distortion through sound processing. That's beside the ideological argument against distortion, the "transparent from the studio" unflinching accuracy routine, which each listener will have to debate and decide for themselves. Distortion can indeed sound pleasing, and a simple software solution could help any given listener decide whether the addition of an actual tube amp, and the distortion artifacts it would bring to their music, is welcome in their collection or not.
