hehe you sum it rightly.
It takes me some times to get used to the new sound of v7. It's strange to notice that before hearing it, i was not with the idea my setup can be bloated but damn it was. I also noticed this "little more in the upper range" but it was because i was not used to. In my experience, it's more a natural and clean rendition with the v7 and i can crank the volume upper than before (for me that's always a good sign ). As you said "resolution, soundstaging and bass definition are concerned".
About the Singularity, it seems that even a good DDC like the Singxer Su1 must benefit from higher processing and shorter signal path. It's definitively the weak point here because the processing of the Singxer must be quite high for the older design. I think we should make the try when it's available About the solderiing there is not that much wiring (14 wires but I'll probably found a tech somewhere to do it) !
On a side note; Kingwa said they have finished the design of a new FPGA DDC but are quite busy now so no announcement yet !
