luisdent
- Oct 25, 2012
Besides the normal tip rolling, I would also play around with insertion angles. Unfortunately for my ears, the best sound quality comes out when the earphones are placed at a relatively uncomfortable angle (not unbearable, but still not as comfortable as they can be). I'm thinking that this magic angle for me is where the bore is least obstructed by my inner ear canal.
I angle mine up a bit as well, as seen in my previous photos. For me, the key is keeping them as shallow as possible,while still being sealed well. I reccomend people start pushing them in until they're just far enough to not fall out. Then move them in slowly as you listen for a minute at a time. You should find a sweet spot where they sound most reference.
Once you have that spot, i usually push them in to that depth and then lift the earphones in a way that lets air pressure equalize again. Then within a minute everything is perfect. They still sound 90% if i just stick them in, but sometime it takes longer to equalize if i don't do it myself. But it usually does equalize on its own just much slower...
