Hello everyone! It's been awhile since I've posted an opamp review here, but I finally got my hands on another opamp that pairs well with the XD-05+ and wanted to share. Some time ago I ran subjective tests on
43 different opamps in the XD-05+ (42 at once, and another later on). Since that point I've been happily enjoying the XD-05+ with an AD827SQ as my favorite, but I've always been curious about some of the other higher end op amps out there. The two I've been most curious about are the Burson V6 Classic & V6 Vivid. I didn't try them before as I knew they wouldn't fit in the XD-05+ case, but it never stopped me from being curious. Well, fast forward to now and I finally have my hands on a V6 Vivid (no V6 Classic just yet).
V6 Vivid with an extension lead. The capacitor next to the opamp slot blocks the V6 from being able to sit flush. Only options are to either relocate the capacitor, use multiple adapters to raise opamp slot, or use an extension:
Below are comparisons to some of the other top performers in the XD-05+:
Burson V5i
The V5i is a top contender for being one of the best opamps in the XD-05+. If you read the entire thread you'll find it's the thread favorite, being almost universally praised for improving the sound over the stock op amp. Compared to the V6, The V6 is significantly clearer than the V5i. I wouldn't consider the V5i to be dark or muffled, it's closer to clear than dark, but it does end up sounding more congested and muted compared to the V6. Clearer doesn't mean brighter here, as the V6 also has more fullness on each note. On the V5i that fullness is replaced with a little sharpness. The V6 also has a minor amount more stage width, similar depth, clearer separation, more note impact, additional detail, and improved bass control. Basically it's an upgrade across the board.If you like the overall V5i sound and want further improvements and fixes, then the V6 is a definite upgrade. Of course, if you don't want to modify your XD-05 in any way, the V5i is still in the top tier for the XD-05+.
AD827SQ:
The AD827SQ has been my favorite op amp for quite some time, and has been my top recommendation for a neutral op amp in the XD-05+. Comparisons here get more complex and are more subtle than other tests so I'm listing them out below:
- V6 is moderately clearer sounding vs the AD827SQ. In direct comparisons the 827SQ has a warmer sound. The V6 doesn't sound brighter, just clearer with the same overall note timbre.
- Both the V6 and 827SQ have the same bass quantity, but the slam is slightly improved on the V6 due to the clearer presentation.
- The 827SQ is more airy, but the V6 has improved note placement and each note is fuller sounding. This leads to an interesting situation where the 827SQ gets more micro detail due to hearing each sound expanded in a diffused way, but at the same time the V6 has more micro detail due to how precise & full each note sounds. All things considered, the V6 has more perceived detail.
- V6 has a slightly wider sound stage
- V6 has better instrument separation despite not being as airy.
- 827SQ has a bit more treble extension. The V6 isn't soft in treble, but it doesn't have as much of an edge on each note.
- V6 has significantly more impact on each note, wheras the 827SQ is more laid back.
In an overall comparison the 827SQ and V6 are quite close in overall sound quality, but the V6 is more refined. The AD827 sounds wonderful, but I do prefer the V6 due to the increased dynamics, clearer presentation (which I typically prefer over added warmth), and improved stage.
Muses02:
The Muses02 is similar in tonality to the V6, both having a clear presentation with great note impact. Instrument separation is also similar, with the V6 having a little clearer separation. Where the Muses02 falters is a moderate amount of compression compared to the V6. This leads to a reduction in sound stage width, squishes notes a little, and reduces overall detail. Despite this the Muses02 still retains a mostly holographic sound. The Muses02 is also leaner, with less fullness on each note and a slightly elevated treble. This combination pushes the op amp a little closer to a U shaped sound. With this leaner sound the Muses02 ends up with slightly more impact on each note compared to the V6. Overall the V6 shares a similar clear tone but with much less compression, more stage, and a generally fuller more neutral sound all around.
Muses03:
The Muses03 has a much more up front presentation when compared to the more holographic sounding V6. It's about the same overall sound as a Muses02 with stage depth reduced, less compression, fullness is increased, and the tonality is lowered to lower than neutral. Stage depth on the Muses03 is small, but the width is excellent. The V6 has more depth, and is very similar in width. In prior testing I found that the Muses03 had the largest stage width of all the opamps I tried on the XD-05+, so the V6 shares the top spot there. Details are similar, but the Muses03 has a little less partly due to a subtle softness on each note. The V6 also once again has more fullness in each note, which further improves detail over the Muses03. The V6 has a correct clear presentation to it, wheras the Muses03 has a rolled treble response that pushes it a little lower than neutral. The Muses03 still sounds great with it's great stage width and details, but the V6 ends up besting it.
Summary:
TL;DR is that in my opinion the V6 vivid is the most complete sounding op amp of all the 44 op amps I've tried. It's typically the top performer in each sound category, and in cases where another op amp is better in some aspect the V6 is still a top contender. The V6 Vivid takes the clear tonality of the Muses02, sound stage width of the Muses03, depth of the V5i, bass quality from the 827SQ, and note timbre from the 827SQ. Take that package and add in the best detail, note placement, separation, and holographic sound of all the op amps I've compared. Finally sprinkle in great dynamics on every note. Overall the V6 has the best qualities from the top performing op amps in the XD-05+ without including their drawbacks.
The Elephant in the Room:
The V6 is big, too big for the XD-05+. I looked around in the case to see if I could relocate any capacitors to make it fit somewhere, but I'm not seeing any immediate solutions. The only good options I can see are to either keep the case open (like in my screenshot above) for desktop only use, or cut a square above the opamp portion of the case and cover the opamp with something sturdy and non-conductive. One such creative setup was posted
here by Vannak. I'm personally thinking of cutting the case then attaching a top plastic piece from a vending machine toy (you know.. those rounded clear plastic bubble containers that have a toy inside). In the end my XD-05+ would look like a Jetsons car, but the sound would be worth it
