Paulus XII
Formerly known as FW214b
Has anybody here compared the Xduoo X3 with the Cowon Plenue D? Could they be at the same level? Or close?
plenue d presentation is way cleaner than x3, x3 has more bass and warmth. Resolution wise, plenue d winsHas anybody here compared the Xduoo X3 with the Cowon Plenue D? Could they be at the same level? Or close?
Hi,My Xduoo x3 won't turn on.I used it for a few days with no issues,but now doesn't react to anything. I can't even connect to PC,does nothing for reset button. The signal comes on, then shuts off.
I am adviceless.
Can somebody help please?!
Thank you.
Can anyone compare it to ibasso dx80?
dx80 is better than x3 in every aspects
Regarding the SQ with stock FW and Rockbox, a few people on the thread say the stock FW sounds better. At the same time, there are some of us who think Rockbox sounds great so I don't think there is a general consensus on the issue. I have not done much AB testing but I personally do not notice a difference on my Rockboxed X3 or Clip+ but perhaps I do not have a critical ear, YMMV. One thing to note is that Rockbox does not allow for hi-res playback.
Rockbox can be installed regardless of which computer OS you use because everything is done on the microSD card. I do not even have to connect the X3 to the computer, I just use a SD card reader.
But if you need to connect the X3 to your Mac, then yes it can be done, I think there is an issue with hidden files which is explained in the 1st post of this thread:
http://www.head-fi.org/t/803844/rockbox-xduoo-x3
I think the trouble with Rockbox is choice. Too many screws to be turned. Some of the sound setting are not beneficial, subtle changes accumulate to a brew. If you know what to do and take your time Rockbox can sound great.
I have also found that the X3 is a bit picky regarding earphones. Some of my IEMs that sound great with the iBasso DX80 and DX90 do not so with the X3 and no amount of EQ can change that. When I plug the Phonon SBM-02 full size headphones (EQ off) in it shines however.
