sure did, but as the minimum volume setting was too loud for me with my most sensitive stuff, hiss became a secondary problem. and IEMs with lower sensitivity to use quietly at home, well, they were less sensitive so I also had less hiss.
both problems are caused and solved the same way.
Haha same here... it's back again. Less frequent than before though.
I guess swapping this card for another brand would be the wise choice. But again it's not frequent... can live with it. This card though, with this X2 is lasting longer per charge. I haven't tested it extensively, but I observed nice difference where Sandisk class 10 with X2 offered less batt life.
This is most likely a tagging issue, if you can dedicate one micro sd card to X2, earlier in the thread I talked about removing all tags from all files because X2 doesn't require them since browsing is completely folder based. You can load your entire micro sd card into MP3Tag and remove them all in one hit to eliminate most problems.
I don't have a 32Gb or higher capacity card from another brand so can't say. But that does makes sense and explains the stuttering on Strontium cards (if it is related to the card that is).
