It's a yellow PCB, uses AD8610, single EL2001 per channel, BUF634 as ground, there appears to be two small caps (mini wimas?) near the opamp, then there are two large wima caps (1,0 uF MKP 10), two large elna cerafines (25v 470uF) and a single smaller cerafine (25v 47uF). I see a place in the board that says XFEED with some soldering marks, cool its got internal crossfeed!? |
That's a revision I prototype from late March or early April. It's not actually a "META42"; you could call it an ETA42, since it was made before Morsel got seriously involved. (AFAIK, her only contribution to that revision is the use of the TLE2426.) What that board is missing relative to the v1.0 version, ignoring things like size and layout issues:
1. Multiloop topology. Revision I allowed local or simple global feedbacj, Eric probably used global feedback which means...
2. ...that the board's crossfeed pads won't work. They will only work when you configure the amp for local feedback only, in which case you get errors from the buffer creeping into the sound. That's why there isn't a specific set of crossfeed pads on the final META42 -- the idea is that you just put it "in front" of the amp section. I've built a few META42s with that layout, and it works well.
3. Provision for output resistors, should you care.
4. Virtual ground buffer is another EL2001, for lower power supply ripple vs. using a BUF634.
5. We ditched the power supply "stability" cap -- the 47uF Cerafine on your board. Morsel deemed it too silly to live.
6. Several small tweaks.
To touch on a few other topics raised in this thread:
Does the META42 compare well to $2-3K amps? I have no idea, since I've never heard such a thing.
Regarding interference: I've
tested the final META42 pretty hard for this. I won't guarantee that the META42 can't be interfered with, but I certainly wouldn't say it's "easy" to get interference with it, either. The ETA42
does favor wiring simplicity to layout tightness; the META42 takes the opposite tack, so there are no layer changes or vias, and the traces are all a lot shorter. Perhaps this explains the interference Eric found with that board.
There's another possibility, if Eric used an ALPS Blue Velvet pot: these pots have to be case-grounded to avoid adding noise, in my limited experience. The META42 board has a provision for this: the PG pad. (Pot Ground) If you use a metal case, you get case grounding for free -- if you use a plastic case, you need to ground the pot to the board.
