Spacehead
- Jan 1, 2010
ground is buffered with OPA633, it has plenty of current capability. Sijosae Class AB discrete buffer (bc337&bc327) works very well in this circuit, which is Cmoy style, and buffers are inside feedback loop (wire is as short as possible)
I am trying to study Walt Jungs Diamond buffer article http://waltjung.org/PDFs/WTnT_Op_Amp_Audio_2.pdf
My "input" resistors are now 10.9 ohm , emitter resistors 3.8 ohm, constant current resistors 620 ohm
between op amp and buffers there is 200 ohm resistor. I have decoupled buffers with 100 uF capacitor rail-to-rail.
I tried and added red leds to BD139 and BD140 base and another end to output, it didn't help.
What disturbs me most, is that BD139 and BD140 don't get warm at all. They are actually cold. I wonder if it would help to lower that current source resistor again to 200 ohm. But ?! hmm, could the JFETS (I used 2SK117) limit the current ?! If removing them would release the circuit so that there would be enough current for 32 ohm headphones (40-100 mA)?
Originally Posted by hiker101 /img/forum/go_quote.gif That buffer is meant to be wrapped in a global feedback loop- that's why it's suggested as an option for the PiMeta. It's not clear how your circuit is set up in that regard. It's also not clear what you're doing about the ground, maybe that's the part of the circuit that's current starved. You said you had another class AB buffer working in the same circuit- was it a discrete buffer, or something else? |
