Zin_Ramu
- Aug 19, 2002
As JahJahBinks pointed out within a particular bit rate VBR > ABR > CBR, so rather than choose between 128 and 320 investigate the VBRoptions. The most popular of which are --alt-preset standard and --alt-preset extreme. Again see the link I posted above for directions on how to use those presents within EAC (not EMC btw).
Then do some testing, with your ears and your system to see if you need standard or extreme. I personally find standard to be sufficient for most albums and since HD space is a bit of an issue for me I went with that. Others can tell a difference on some recordings so they use extreme always just to be safe. Its your call choose a couple tracks from your favorite albums and do some testing. Compare .WAV, standard, and extreme and see if you can discern any differences between the three. If you can consistently pick out the standard MP3, you should go with extreme.
Zin
Zin
