preauxtip
What is the Audirvana app like ? Is it a dedicated music playing app ?
Am curious as to how the Topping (and other Chinese) DAC performs, too. How do you find it ?
Monitor Audio are a good choice of loudspeaker, rarely if ever been disappointed by them, quality drivers and a quality finish, usually, with a fair choice of veneers, very nice indeed.
So Audirvana will interface with Tidal and Qobuz as well as integrate in your local files and then enters in an Exclusive mode (WASAPI, ASIO, or Kernal) with your DAC to bypass windows resampling your files to 48khz (or making you constantly change that setting). Then it also allows you to add in upsampling, digital signal processing through VST3 plugins (like a parametric EQ plugin or a tube harmonic plugin) if you want. It also has a smartphone remote control app so I can sit on the chair away from the computer and still control my music. For an extra $6 a month its a great thing.
For the Dac my Geshelli isn't Chinese, it's made in the US actually. I do have some Chinese DACs however and they work fine, but the J2 is fantastic. The Topping L70 is my headphone amp and preamp and it is fantastic, I absolutely adore it for its features and price. However I will note that specific unit has a very low input impedance so it will not pair well with some input sources that have a high output impedance like say a Denfrips Ares DAC.
