Saintkeat
- Jan 23, 2009
i was asking whether anyones done it...
Ok I've got a tweak for you that helps the IE8 mate to different tips. I used FTPE silicon plumbers tape (that thin white stretchy tape you put on pipes to seal them) around the stem of the IE8. This thickens the stem a bit making a tighter fit. I also changes the resonant frequency of the sound chamber inside the phone. It makes the stock foam tips sound less thick and helps return treble sparkle.
For the foam tips I use about a 6 inch piece that I fold lengthwise in half then wrap tightly around the stem.
For the uncored Olive I use about 12 inches of tape folded in half lengthwise and wrap tightly. The modded Olive has too much space in the core and is loose around the stem. With the tape it is a much tighter seal, and they don't fall off as easily. It helps make the bass tighter and more dynamic and a bit deeper, the treble is better and the soundstage is bigger.
I also suspect that this might improve any Comply tip on any headphone and make it sound less rolled off.
Ah I see. Ill have to give those specs a try. Do you have any pics you could post up of the modded tips you made?
Quote:Ok I've got a tweak for you that helps the IE8 mate to different tips. I used FTPE silicon plumbers tape (that thin white stretchy tape you put on pipes to seal them) around the stem of the IE8. This thickens the stem a bit making a tighter fit. I also changes the resonant frequency of the sound chamber inside the phone. It makes the stock foam tips sound less thick and helps return treble sparkle.
