Arniesb
- Dec 12, 2013
I think Galvanic Isolation is to break ground loops... I dont think it lowers noise... Even read somewhere that galvanic isolation lowers performance of Source clock, but i cant guarantee it.Having both looked into this quite a lot, and also trying various products myself recently, I figured I'd post a response to clear things up a bit.
There are two main factors that will affect the quality of the eventual i2s signal processed in the dac:
-Jitter
-Ground plane pollution/power quality.
The latter is a simple matter to resolve. Simply avoid a direct electrical connection to a noisy device such as a PC. If you want to try this yourself and keep things a fair test, just get a $30 raspberry pi3b+, install ropieeeXL and use that. You will likely hear a noticeable improvement not due to any digital change, but simply because the 0v reference ground plane is not being contaminated by the noise from the power hungry PC. Though if using a battery powered laptop this may be less of an issue.
This is the same reason why high quality linear power supplies can bring a benefit to audio equipment.
If you want to step this up, you can get a high quality streaming solution such as a pi2aes, SotM SMS200-ultra, Sonore Ultrarendu, or Lumin U1 for example.
Jitter however, is a bit more of a complex beast and depends on a few things.
- When using USB (with proper drivers), it is asynchronous. Meaning the dac USB module calls for additional data when it needs it, and converts to I2S using the dac's OWN clock. Therefore jitter will be dependant on both the quality of the device clock, and the USB implementation in the dac.
- When using any form of SPDIF (AES, Coax, Optical), the clock signal is encoded within the stream, and so jitter is dependant on the SOURCE (your PC). This is why a high quality digital-to-digital converter such as pi2aes, Singxer SU-6, Matrix X-SPDIF 2 etc will sound better than SPDIF from your PC. Everything is still digital "Bit perfect", but jitter is considerably lower than the output from your PC.
Jitter on isochronous connections like this can also be fought with a high quality PLL and FIFO buffering, such as that found in the holo May. You can see in measurements here that even with high amounts of artificially introduced jitter, the may's PLL when enabled, made the dac almost immune to it. https://www.audiosciencereview.com/...may-probably-the-best-discrete-r2r-dac.10161/
Its worth noting that while optical connections give the benefit of galvanic isolation, they also usually have higher jitter than coax.
- When using I2S from a DDC, again the clock is part of the stream, however i2s uses multiple lines, with the master clock being separate entirely from the data and word clock. Meaning it is in theory better than SPDIF which encodes all of this into one stream and has to be "unpacked" at the other end. Though has the disadvantage of usually only being able to be done over very short runs.
TLDR:
If you want to use the best connection, use the best DDC/clock source you have.
That might well be your dac's internal DDC over USB.
But for $200 you can get a pi+pi2aes which is likely to be better.
However, galvanic isolation will almost always bring a benefit, and you can do that for $30
I think Uptone owner said that Power supply and Clock brought much bigger improvements than Galvanic Isolation on his reclocker.
In my case Ifi nano reclocker brought much bigger difference than Laptop running on battery.
Sound was much more realistic, with a lot better resolution, but it sounded very harsh.
Tried ifi micro usb 3.0 at dealers place and it was even better with more resolution, depth and realism. Still though it sounded harsh.
I think both of these sounded harsh, because all electronics is close to each other in small cases and both were equipped with switched power supplies.
Now Innuos phoenix dont have any bad qualities according to many who listened it.
