What equipment would I need to hear the difference between a 320kbps file and a losless file like FLAC?
Jan 7, 2014 at 11:45 PM Post #16 of 100
  OP, this is what matters.
Leave headfi now, while you still can.
And this coming from such a new joiner as yourself!
I'm sure you, like myself, have been lurking here for way too long.  Yes, it's a bit of a time-sink, but at least we both found the sound science forum.  No longer filling my head with ramblings about vacuum tubes and 99.999999999999% pure copper sure does help.
Jan 8, 2014 at 7:39 AM Post #17 of 100
Yeah I've been lurking a while
Jan 8, 2014 at 8:17 AM Post #18 of 100
When I first began listening to lossless files and changing my collection to lossless from itunes AAC, I did not hear too much of a difference honestly. At that time I used good mid/high level headphones like beyerdynamic dt990 32 ohm and denon d5000 out of my computer using foobar. The only initial changes that I noticed after a few minutes of ABX was flac files semmed to have more sound/noise at all times, compared to AAc where I was used to the missing samples, and thus seemingly emptier sound of songs. The other main thing was flac files seemed to have crispier treble, and in general a tad higher treble (although I think the higher treble sound is due to the playback source of my default computer dac/amp, the no-name internal ones). That was all at first.
eventually after a few months I got used to flac files, and began hearing slight extra details in all that extra noise that was there initially. Then when i played AAC again, it felt noticeably emptier sounding, like something, very little something, was just missing. Otherwise the only thing that can go wrong with flac is how you actually get flac songs. like if you rip from a cd, and use a good ripper, then you should be ok for consistant sound quality. But if you are like me and occasionally torrent some stuff, then the flac files can vary in actual sound quality, because they reveal anything that exists on the files. so I have some albums that sound perfect, and others that are too sibilant, or others that are too quiet. small variants but, the sibilant ones can be annoying. Compared to torrenting an mp3 or AAC file, witht he missing samples, it kinda fixes some of those minor varients. If you buy all your music and rip from a cd, then non of that should matter lol. bandcamp has great flac files, I love it when bands post their music there. or use hdtracks (but thats way pricier compared to bandcamp which can be free at times or very cheap).
So I guess after that essay of text, the overall differences are in the sound signature + fullness of the song, and less of the quality of the sound itself. as in the quality from 320 to lossless will be exactly the same in terms of clarity and sharpness and distortion free, just with practise you will definitely start hearing where the compression removed certain samples of frequencies, and you start only using flac, unless you dont get bothered by it enough. I have mostly flac, with some 320. And all my flac, besides like 3 albums, is all in 16 bit 44.1, so just go with flac if you can handle the file sizes, or stick with 320 to save space.
hope this helps on a less technical level :)
Jan 8, 2014 at 1:24 PM Post #19 of 100
There are no missing samples or "empty sound" in AAC files. At 192 and below there is a small ultra high frequency rolloff, but above that, the high end response is very, very close to CD quality. The frequencies we're talking about would only be audible in triangles and certain cymbal crashes. Not the music itself. At 256 and above, I'm sure no one could hear that minute difference.
You're describing a textbook case of expectation bias there. If two sounds are subtly different, the difference would be most evident in a direct A/B comparison. Noticing details weeks or months later has more to do with how close you are listening than it does audio fidelity. "Sound signature" and "fullness of sound" are directly related to audio fidelity. It's a contradiction in terms to suggest that two sounds can sound different yet have identical fidelity.
Jan 17, 2014 at 2:19 PM Post #20 of 100
AAC does lose certain samples, based off the LSB. Formats that compress the overall size of the file are going to attack some part of the quality. This starts with the dynamic range and then the top and bottom end. I will say when you start getting into the higher compressed files the quality does get better, is not the same. As for what equipment you need, I'd say it's more important to how well you can hear and knowing how a recording should sound.
Jan 17, 2014 at 3:30 PM Post #22 of 100
,,,and not necessarily audible by human ears.
Jan 17, 2014 at 4:28 PM Post #24 of 100
By who?
Jan 17, 2014 at 4:51 PM Post #26 of 100
Most of it depends on how much control you have over your comparison tests. Hearing is "better" when comparisons aren't blind tests. Do a line level matched blind direct A/B comparison of a good codec like AAC at a good bit rate like 256 and suddenly your hearing ability begins to degrade significantly.
Jan 17, 2014 at 5:20 PM Post #28 of 100
Please read the posts here
http://archimago.blogspot.co.uk/2013/01/high-bitrate-mp3-results-part-0-preamble.html
Jan 17, 2014 at 5:46 PM Post #29 of 100
Which adds what to the debate exactly?
Jan 17, 2014 at 6:11 PM Post #30 of 100
There is a section about equipment/price. But the conclusion is up to you to decide/understand.
I just provide some info, the interpretation is partially subjective...
